Needing Help With The Pin Numbers On A Washing 8719 PLL
blake25537
76
27
56
I'm installing extra channels on a Washing PLL 8719 but not sure on the pin numbers like Pin 1 2 3 etc, could some explain please and a pics would be very helpful.
Thank you
Pins 1 and 18 have a "U" shaped cut out on the top of the chip (non-solder side of the board) and usually Pin 1 has a dot (either painted or etched) near it-again on the top of the chip (non-solder side of the board).
David
I was readying some place where there is a mod for the 8917 where you can get 28MHz would you happen to have pics n info on
that one
  • @ ShadowDelaware:
    AKA- UDX122
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
