New antenna from Sirio Gain-Master
I bet the GM will SUCK for higher angle DX due to the lowered TOA. I've noticed the Penetrator doesn't hear dx when my neighbor 2 miles away hears it on his Starduster.
Maybe some truth to the rumor that the Merlin55 outperforms the I-10K, but if so, I bet only with regard to higher angle DX.
Hey Marconi, when you get time maybe you could try modeling a .64 with the additional .015 at the bottom not the top, as I believe it must still top-terminate at the 270° current phase point.
Seems your eznec representation shows a higher angle & less gain for the .64 compared to the .625 and that would be wrong as the .64 is already known to have a few degrees lower TOA and a hair more gain.
You're right 007, that's what these models show.
I've heard similar stories as you note, but nobody has ever shown me an ounce of support for the idea that a .64 makes more gain at lower angles than a .625. I sometimes post the chart below to support my ideas. I suggest you read the captions below the images carefully for the true meanings of these charts.
This chart probably originated from the testing of the 5/8 wave idea back in the 1920-1930's and it doesn't show the .64 wavelength at all. Would you consider this chart strange in that it doesn't indicate a .64 wavelength? If you have a reference for the claim you note, then I would appreciate the reference of a link to it.
I make no claims for the accuracy of my models, they are what they are, and I'll encourage and consider any critique that will give me better knowledge. In this case with models, I use them simply to support my thinking about what knowledge and trends they might reveal, trying not to make claims out of thin air. I'll change my mind on any topic with good arguments or if I'm convinced I'm wrong thru reliable type evidence. I'm here to learn something and not to defend bad ideas to my dying breath, even though I'm sure I have a few.
I didn't use tapper in either model. I arbitrarily made the radiator tubing diameter .75" and the radials .50" just to try to get closer than thin wire will get me to the real physical antenna. My Eznec version is limited to 20 segments per model total, so I can't get too ambitious in my efforts.
There are guys out there with more and better knowledge on Eznec and they can surely prove or disprove these models if that is necessary.
007, I was as surprised as you were in these results, right or wrong.
Regarding the raised GP on the HyGain Penetrator. I have always thought this feature added something positive to that antenna design, but it was just a guess with me cause I can't prove anything---not even real world experience with that one. You'll have to wait till I get excited enough to get a better version or one of our local modelers will have to try and model it for us.
I just know enough to be dangerous sometimes.
Another thing I noticed about the .625 vs. .64 is, the .64 should be much more efficient to match, because it seems at some point just beyond the .625 length---something happens with the radiator where the value of R and X both drop down much closer to the desirable range considered good. So, the matching requirements should be much less and therefore it should provide for much less loss in matching or transformation. Whatever advantages that might really have in the real world---I do not know.
I also disagree that the GM will suck with higher angle DX, because if you check the pattern I posted for the 5/8 wave dipole you will see there is still a nice gain noted between 10 to 25 degrees. There is also a 40 degree lobe area with some gain, but I don't think that will be very productive except maybe for backscatter when conditions permit.
When Radio Shack sold their .64 they said it was the best so since they are the ultimate, "You've got questions, WE'VE GOT ANSWERS" corporation, how can I not believe them?
But seriously, you raise some good questions about reference standards and just where did that .64 info originate. I guess I'll be putting some overtime into researching that.
If there's a way you can try redoing your eznec plot on the .64 by adding .015 to the bottom so the top of the current null is at the very top of the radiator, I'd like to see if eznec shows a difference.
I gotta run, another dinner invite. Interesting post!
I think you are referring to this image, right?
marconi-albums-i-10k-625-vs-i-10k-64-picture2214-i-10k-64-01-antenna-view-antenna-uses-dimentions-i-10k-except-i-added-about-6-inches-make-64-wavelength-i-also-used-75-radiator-50-radials-simulate-closer-actual-tube-size-i-did-not-use-tapper-may-make-some-difference-results-but-i-dont-believe-differences-will-remarkable-relative-pattern-gain-angle-more-experience-modeling-may-answer-important-question-however.jpg
Here is the same antenna. I just move it over so the x,y,z notations would not interfere with the actual antenna view.
007, since we have all learned not to trust the words of any antenna manufacture and for sure their marketing department's words, give me a reference with some effort and work done if possible. Many years ago I read a report produced by some Japanese RF engineers trying to duplicate the U.S. Broadcast Industry report early in the 19th Century. They supposedly found that .64 was better that the US report claiming that .625 was best. I've looked high and low without success. The report is out there somewhere and there are references to it in later journals on the subject. I think there is a foot note on it in the article entitled "The 5/8 Wavelength Mystique" published by Donald K. Reynolds K7DBA. A copy is in The ARRL Antenna Compendium, Volume 1.
FlatsideDX, I just read some Internet reports from Europe that are not too flattering for Sirio's New Gain Master as compared to an A99 and a Big Stick. At 130 GB, and maybe over $200 US, I doubt we'll see much excitement here---to say nothing about the low power handling capabilities in our "Power Crazed" US market.
I'm still hoping for better reports and a much lower price though.
Since the materials used don't look that hot to me; it looks like they might have priced themselves out of the market.
That video - while appreciated - makes the antenna look a bit shoddy.
We will see what happens.
Marconi,
I still have not received my new shipment of stock. I have 125 antennas on order and the Gain Master is in this order. It looks like my order has been placed on the same ship as the stock going to H&Y and I will have it in about a week or two. I have to be honest and say I'm not sure how much testing I can give this antenna right now. I have a beam, 75 meter quad and a 2 meter antenna going up by bucket truck within the next few weeks.
This is going to cramp the amount of time I can give testing the antenna. Especially with poor weather coming. It seems as though reports from Europe are going to be in before I can test. I am very surprised to see the one test claims full S unit behind the other common fiberglass sticks.
I'm regularly in touch with the engineers at Sirio and have had an in depth conversation about the Gain Master with them. Sirio is one of the few companies that actually post true gain on CB antennas. I find it nearly impossible that they would bring this antenna to market advertising it at least 1 db over other 5/8 waves only to find the exact opposite.
They have a sophisticated RF test range and a million dollar anechoic chamber to arrive at accurate gain figures in addition to the latest computer modeling software that makes EZNEC look like child's play. I'm still betting this antenna is a performer.
Good to see you're still kicking Shockwave. I understand, you have work to do, and that comes first. I remain hopeful as well.
Marconi
I too read a European post stating a similar negative finding. I certainly took it with a "grain of salt" and I hope for better reviews when they start rolling in. I have a use for this antenna if it lives up to its hype, but not at $200.00. The 500 watt rating works for me but I'm sure it will be a killer for many. I can't wait to see a good honest comparison review from someone. It doesn't have to be the biggest, baddest antenna to sell well unless the price is overly prohibitive. It does need to stand up well against the other stick antennas performance wise or it will certainly crash and burn in the USA. (y)
Marconi,
Since the A99 is the bottom of the barrel I have no doubt those so-called test results were either intentionally bias, or there was some other issue, perhaps a defective one in the batch, or someone used 700ohm coax, etc....
These's too much thought put into that design not to work like a greased dild... well, you know. :whistle:
And I'll keep looking, too!
But considering the genius emanating from Sirio, I'm wondering, if the .64 IS better, why wouldn't they choose a .64 over a .625, especially when the impedance is supposed to be closer to 50 ohms prior to the introduction of a matching network...?
Things that make you go, "Hmmmmm".
The difference between a .625 wave and a .64 wave antenna is like taking a glass full of water and adding one drop to it. At the end of the day you really can't tell you drank an extra drop but you might feel better knowing you got more. I also find it interesting that the marketing tactic of .64 wave exists on no other frequency then 27 MHz. Either the .64 wave is ineffective on all other frequencies or the BS factor doesn't sell as well elsewhere.
Now THAT… in my humble opinion… was WELL said! :D
