S
slickpenguin
Guest
Im planning on getting a pro 94 or 95, and was wondering if its worth buying a mag mount scanner antenna, or if its just as good as leaving the stock antenna on the scanner. Ive seen a couple for around 20 bucks on ebay, but I know just about anything is suitable for an antenna using scanners. Basically, is there any advantage gained by having an antenna mounted on your roof over having the stock antenna inside the car with you?
</p>
</p>
