President AX-7 C.B. wiring code
Raccoon
Oct 27, 2005
217
108
53
56
www.youtube.com
I've been searching for the wiring code for hooking up a "Cobra High Gear" noise canceling hand held mic to a "President AX-7" , which is a 5 pin mic set up . Everytime I think I've got it ... it turns out I don't . So after numerous hours and to many tries to count , I decided to ask around . Any help would be greatly appretiated . :LOL:
Heres what I think it is, this radio is similar to a GE radio, the wiring goes like this. First the DIN plugs dont go in a usual numerical order. If you are looking at the plug from the wire end of the plug solder-terminals with the notch in the plug pointing down it goes 1-4-2-5-3. That being said.....
1-ground
2-No connection
3-Transmit
4-Audio
5-Receive
I think that should do it but drop me a PM if it doesnt.
