Hi,
I've bought a used President George CB radio but I can't put it in export mode,
I've tried a lot of times to do these instructions :
a) Turn your set on by pushing POWER.
b) Turn your set off by pushing POWER,
c) Depress POWER and keep pressed down. Your set goes on and then goes off.
d) Keep POWER depressed and press PA and DIMMER simultaneously.
e) Release POWER after 5 sec. while keeping PA and DIMMER pressed down: ''codE'' flashes in the display for 5 seconds.
f) ''codE'' disappears and the display remains lit up.
g) Release PA and DIMMER.
h) Press M1
But impossible to put in in export mode, when the "codE" should dissapear, on mine it stays blinking.
Do you know what can I do ?
Thank you very much
h) Press M1
Thank you very much
