rci 2995 / tx = grzzz !! ?
I have a RCI 2995dx. I don't hear any noises
when i key up.
Run a fan kit on it to keep it cool.
Send it back if your hearing unusal noises when Tx-ing.
I'm not following you here.........you say you have to buy a base radio so your happy. Thats fine. Or did you already buy a 2995 and you have a question?????? And what in the sam hill is " transfotmateur. " Wow, almost gave me a headache re-reading that post several times.
Bonjour Mikola,
Est'ce que vous entendez ce bruit dans la chambre, un bruit accoustique?
Ou est'ce que les autres entendent ce bruit dans leurs radios? Un bruit dans votre signaux?
Pardonnez mon francais primitif. Votre anglais c'est meilleur que mon francais.
Post-Script for english speakers: The line frequency in France is 50 Hz, not 60 like in the USA. Might make the transformer's core 'buzz' a little. Gotta figure RCI designed the transformer with that fact in mind. Never have heard one do that on 60 Hz juice here in the USA. Never.
hello nomadradio & all !
Nomadradio, ton francais est exelent, bravo!
oui le bruit est au niveau de transfo; mais les autres OM de l'entendent pas. pense tu que c'est a cause de la difference 50/60 hz ? Si oui peut'on le modifier ?
merci de ta réponse QRO
si joint une photo du shack pour le fun
