If the radio works fine in the car/truck and then when moved indoors it has a problem, then the power supply is defective or too small to run the radio.
What size is the jpower supply?
How many Amps is it rated for?
A Indoor power supply converts 120 volt AC into 12 volt DC.
They have limits on how many amps they put out depending on different models.
If it is too small It can not supply enough current for your radio to work properly.
A stock cobra 29 should not draw a lot of power.
