Alright so I acquired a GE Superbase that at the moment is not so super. The rig received superbly on all modes, but would not transmit. Key of the mic would produce a little needle bump, but no mod., no transmit power. Nothing even to another radio.
Having the ambition and little knowledge I do thus far, wired up a new 636 for starters <which produced the same results as the original mic>, then proceeded to check the switching transistors on the board which all seemed to function according to the schematic. Not so sure of what I've actually done, but with the setup of the TWO boards, I disconnected the harnesses connecting them and it seems as I may have fried the AF AMP chip as the rig went into "assault" mode not having those wired jumpers. Now the IC gets smoking hot and it would appear as I have no audio/recieve at all.<?>
What I'm wondering is did the IC get smoked or did something else get smoked and is now over volting the IC, as I don't think it wise to turn the rig on at all to test any further. .. .
