Transmit enable for mars/cap frq for the TS-430S
AudioShockwav
Extraterrestrial
Staff member
Apr 6, 2005
9,112
9,043
593
Nor Cal Sierra Nevada
For MARS and CAP transmit capability, a minor change is required:
Unplug the DC power cable.
Remove the top and bottom covers of the set.
Locate the RF unit connector 10. Diode D39 is near the connector (labeled D39 on the circuit board). Take a small pair of diagonal cutters and clip the lead at the top of the bend.
Locate IC-2 on the Control Unit, under the IF unit. Resistor R148 is near IC-2, clip the resistor lead.
This completes the modification. Reassemble the unit, being careful not to pinch any leads.
