turbo board project(picture up now)
F
fnkycoldmedina
Guest
i didnt like the way the turbo echo board sounded in my cobra 29 so i proceded to make a project out of it.i got me a project box from rat shack and made me a portable turbo echo box out of it.i mounted the turbo board in the box ...added a 4 pin female socket to connect too ....wired everything up inside that needed to be done,added a on/off switch and a light,then routed everything out the other side via a old mic cord.i had to run a 12 volt line in of course to power it up.so now i have a portable turbo echo that i can use on any 4 pin cobra,galaxy...ect.....as long as i can plug it in to 12 volts.came out pretty good.i also made a access hole in the box so i can turn the preamp up n down at will without having to open the box.these boards have an adjustable preamp on board.maybe i,ll put a pic up soon...........
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=fnkycoldmedina>fnkycoldmedina</A> at: 11/27/03 9:43 pm
Re: turbo board project
looks great man! all you have to do to get your pre-amp adj.pot remotely mounted would be to remove it from the circuit board and measure the value across the wiper terminals and get a chassis mount pot of the same value,drill a hole,mount it,and add jumper wires from the PCB to the new pot! the hardest part would be matching up a knob to the other dual control knobs! good job and you can pat yourself on the back and say"I DID IT MYSELF!"
Slim
</p>
Slim
</p>
  • @ ShadowDelaware:
    AKA- UDX122
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
