Galaxy DX Radios DX88HL
Frequency Counter PCB (EPT210014C)
EPT210014C Trace Layouts
Schematic
Tech Note
Hum in the receive in a DX88HL
Ref#
Description
MFR. Part No.
COUNTER EPT210014C
#MT-140Q-P02
COUNTER P.C.B. 62x51x1.6tmm(d)
EPT210014C
Resistors
Ref#
Description
MFR. Part No.
R2
CHIP/F/R (SMD) 4.7K OHM 0.1W
RCY014724Z
R3
RCY014724Z
R4
CHIP/F/R (SMD) 22K OHM 0.1W
RCY012234Z
R5
RCY012234Z
R6
RCY012234Z
R7
RCY012234Z
R8
RCY012234Z
R9
RCY012234Z
R10
CHIP/F/R (SMD) 100 OHM 0.1W
RCY011014Z
R11
RCY011014Z
R12
RCY011014Z
R13
RCY011014Z
R14
RCY011014Z
R15
RCY011014Z
R16
RCY011014Z
R17
RCY011014Z
R18
RCY011014Z
R19
RCY011014Z
R20
RCY011014Z
R21
RCY011014Z
R22
RCY011014Z
R23
RCY011014Z
R24
RCY011014Z
R25
RCY011014Z
R26
RCY011014Z
R27
RCY011014Z
R28
RCY011014Z
R29
RCY011014Z
R30
RCY011014Z
R31
CHIP/F/R (SMD) 330 OHM 0.1W
RCY013314Z
R32
CHIP/F/R (SMD) 10 OHM 0.1W
RCY011004Z
R33
CHIP/F/R (SMD) 0 OHM 0.1W
RCY010004Z
R35
CHIP/F/R (SMD) 470 OHM 0.1W
RCY014714Z
R36
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R37
CHIP/F/R (SMD) 47 OHM 0.1W
RCY014704Z
R40
RCY011034Z
R41
CHIP/F/R (SMD) 33K OHM 0.1W
RCY013334Z
R42
RCY010004Z
Capacitors
Ref#
Description
MFR. Part No.
C1
CHIP/C (SMD) 0.1UF 50WV Z F Y5V(0805)
CK1104AB7R
C2
E/C 100UF 16WV Z (MINI)
CEM161077Z
C3
CHIP/C (SMD) 0.1UF 25WV M Z5U
CK2104AA6U
C5
CK2104AA6U
C6
CHIP/C (SMD) 33PF 50WV J CH
CK1330AB4A
C7
CHIP/C (SMD) 15PF 50WV J CH
CK1150AB4A
C9
CHIP/C (SMD) 0.001UF 50WV Z SL
CK1102AB7L
C10
E/C 1000UF 16WV Z
CE0161087Z
C11
CHIP/C (SMD) 0.01UF 50WV M Z5U
CK1103AB6U
C12
CK1103AB6U
C13
CK1103AB6U
C14
CK1103AB6U
C15
CK1103AB6U
C16
CK1103AB6U
C17
CK1103AB6U
C18
CK2104AA6U
C19
CK1103AB6U
C20
CEM161077Z
VC1
TRIMMER/C (SMD) 20PF TCZ03P200A110B00
CV038200AY
Crystals
Ref#
Description
MFR. Part No.
X1
CRYSTAL HC-49/U 4.500MHz
EYCAP04500
Inductors
Ref#
Description
MFR. Part No.
L1
CHOKE COIL 470UH
ECCHK16096
Integrated Circuits
Ref#
Description
MFR. Part No.
U1
IC (SMD) TC4093BFN 14PIN
YNTA04093B
U4
I.C.  80PIN LC7232N-8985
YNRG0GX3SP
U5
IC (SMD) BA6250F-TP 16PIN
YNRO06250F
U6
YNRO06250F
U7
YNRO06250F
U8
I.C.(SAMSUNG) 7805 3PIN
ENSS07805Z
Transistors
Ref#
Description
MFR. Part No.
Q1
T/R (SMD) 2SB798DL-(T1)
TY2SB0798Z
Q2
TY2SB0798Z
Q3
T/R (SMD) 2SC2714 -TE85L
TY2SC2714Z
Connectors
Ref#
Description
MFR. Part No.
CN1
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
CN1
WIRE CONNECTOR/H 2P-2P
EX07N48745
CN2
PCB CONNECTOR/S 7P PH=2MM
EX07N48224
CN2
WIRE CONNECTOR/H 7P L=200MM PH=2MM
EX07N48875
CN3
PCB CONNECTOR/S 12P PH=2(WHITE)
EX07N48767
CN3-J306
WIRE CONNECTOR/H 12P-12P L=100 PH=2
EX07W49252
CN4
EX07N48150
CN4-J307
WIRE CONNECTOR/H 12P-12P L=120 PH=2
EX07W49253
Hardware
Ref#
Description
MFR. Part No.
COUNTER COVER
MT2100061X
COUNTER BOX
MT2100070X
BRACKET OF COUNTER BOX
MT2100081X
SPONG 50x30x3t
XZZZ90198Z
SET SCREW M3x0.5Px6
JS053006MN
Copyright © 1998,1999,2000, 2001, 2002, 2003 CBTricks.com
