Galaxy
DX Radios DX88HL
Frequency Counter Board
(EPT210011A) Early Production
Alignment Info
Schematic Diagram
(gif)
EPT210011A Trace Layout
Ref#
Description |
MFR.
Part No.
COUNTER P.C.B. EPT210011A |
#T-106A-P02 |
COUNTER P.C.B. |
EPT210011A |
Resistors
Ref#
Description |
MFR.
Part No.
R601 |
C/F/R F-TYPE 100 OHM 1/4W U |
RCU141014Z |
R602 |
C/F/R F-TYPE 1K OHM 1/4W U |
RCU141024Z |
R603 |
RCU141024Z |
R604 |
RCU141024Z |
R605 |
RCU141024Z |
R606 |
RCU141024Z |
R607 |
C/F/R 68K OHM 1/4W U |
RCU146834Z |
R608 |
C/F/R 18K OHM 1/4W U |
RCU141834Z |
R609 |
C/F/R 82K OHM 1/4W U |
RCU148234Z |
R610 |
RCU141024Z |
R612 |
RCU141014Z |
R613 |
C/F/R 56 OHM 1/4W U |
RCU145604Z |
R614 |
C/F/R F-TYPE 22K OHM 1/4W U |
RCU142234Z |
R615 |
C/F/R F-TYPE 10K OHM 1/4W U |
RCU141034Z |
R616 |
C/F/R 270 OHM 1/4W U |
RCU142714Z |
R617 |
RCU142234Z |
R618 |
RCU141034Z |
R619 |
RCU141034Z |
R620 |
RCU142234Z |
R621 |
C/F/R F-TYPE 100K OHM 1/4W U |
RCU141044Z |
R622 |
C/F/R 1.5M OHM 1/4W U |
RCU141554Z |
R623 |
RCU141014Z |
R625 |
C/F/R 56 OHM 1/4W P |
RCP145604Z |
R626
C/F/R 560 OHM 1/4W U |
RCU145614Z |
Trimmer Capacitors
Ref#
Description |
MFR.
Part No.
VC601 |
TRIMMER/C CV05E3001 30PF 5Q |
CV050300AZ |
VC602 |
CV050300AZ |
VC603 |
TRIMMER/C CV05D2001 20PF 5Q |
CV050200AZ |
Capacitors
Ref#
Description |
MFR.
Part No.
C601 |
E/C 220UF 10WV Z |
CE0102277Z |
C602 |
M/C 0.001UF 50WV K |
CM0501025Z |
C603 |
C/C 0.047UF 50WV SL Z |
CC0504737L |
C604 |
CC0504737L |
C605 |
C/C 5PF 50WV SL C |
CC0500501L |
C606 |
CC0504737L |
C607 |
C/C 3PF 50WV CH C |
CC0500301A |
C608 |
E/C 220UF 10WV Z |
CE0102277Z |
C609 |
C/C 56PF 50WV SL J |
CC0505604L |
C610 |
E/C 1000UF 10WV Z |
CE0101087Z |
C611 |
CC0505604L |
C612 |
E/C 220UF 10WV Z |
CE0102277Z |
C613 |
CC0504737L |
C614 |
CC0504737L |
C615 |
E/C 220UF 10WV Z |
CE0102277Z |
C616 |
CC0504737L |
C617 |
C/C 0.01UF 50WV SL Z |
CC0501037L |
C618 |
C/C 0.001UF 50WV SL Z |
CC0501027L |
C619 |
E/C 220UF 10WV Z |
CE0102277Z |
C620 |
CC0504737L |
C621 |
CC0501037L |
C622 |
C/C 120PF 50WV SL K |
CC0501215L |
C623 |
C/C 120PF 50WV CH K |
CC0501215A |
C624 |
C/C 560PF 50WV UJ K |
CC0505615G |
C625 |
C/C 56PF 50WV CH J |
CC0505604A |
C626 |
C/C 12PF 50WV CH J |
CC0501204A |
C627 |
CC0501037L |
C628 |
C/C 15PF 50WV CH J |
CC0501504A |
C629 |
CC0504737L |
C630 |
C/C 47PF 50WV CH J |
CC0504704A |
C631 |
C/C 33PF 50WV CH J |
CC0503304A |
C632 |
E/C 220UF 10WV Z |
CE0102277Z |
C633 |
CC0504737L |
C634 |
CC0504737L |
C635 |
CC0504737L |
C636 |
C/C 5PF 50WV CH C |
CC0500501A |
Integrated Circuits
Ref#
Description |
MFR.
Part No.
IC601 |
I.C. (TOSHIBA) TC4511BP 16PIN |
ENTA04511B |
IC602 |
I.C. (TOSHIBA) TC5032P 28PIN |
ENTA05032P |
IC603 |
I.C. (TOSHIBA) TC4572BP 16PIN |
ENTA04572B |
IC604
I.C.(TOSHIBA) TD6102P 9PIN |
ENTA06102P |
IC605 |
I.C. (HITACHI) HD10551 8PIN |
ENHI10551Z |
IC606 |
I.C. (TOSHIBA) TC4518BP 16PIN |
ENTA04518B |
IC607 |
I.C. (TOSHIBA) TA7310P 9PIN |
ENTA07310P |
IC608 |
I.C. (MOTOROLA) MC14060BCP 16PIN |
ENMC14060B |
IC609 |
I.C. (MOTOROLA) LM7808 3PIN |
ENMC07808Z |
Transistors
Ref#
Description |
MFR.
Part No.
TR601 |
T/R 2SA733P |
T2SA00733P |
TR602 |
T/R 2SA733P |
T2SA00733P |
TR603 |
T/R 2SA733P |
T2SA00733P |
TR604 |
T/R 2SA733P |
T2SA00733P |
TR605 |
T/R 2SA733P |
T2SA00733P |
TR606 |
T/R 9018G |
TZZZ09018G |
TR607 |
T/R 9018G |
TZZZ09018G |
TR608 |
T/R 9018G |
TZZZ09018G |
TR609 |
T/R 9018G |
TZZZ09018G |
Crystals
Ref#
Description |
MFR.
Part No.
X601 |
CRYSTAL HC-49U 2.67375MHZ 20PPM |
EYCAD02673 |
X602 |
CRYSTAL HC-49U 3.2768MHZ 20PPM |
EYCAD03276 |
Inductors
Ref#
Description |
MFR.
Part No.
T601 |
I.F.T. |
ECIFT12012 |
T602 |
I.F.T. |
ECIFT12070 |
Diodes
Ref#
Description |
MFR.
Part No.
D601 |
DIODE 1N4148 |
ED1N04148Z |
D602 |
DIODE 1N4001 |
ED1N04001Z |
D603 |
ZENER DIODE 2.4V 0.5W |
EDZD05249Z |
D604 |
DIODE 1N4148 |
ED1N04148Z |
D605 |
DIODE 1N4148 |
ED1N04148Z |
D606 |
DIODE 1N4001 |
ED1N04001Z |
Connectors
Ref#
Description |
MFR.
Part No.
J10 |
PCB CONNECTOR/S 4P L TYPE |
EX07N41283 |
J11 |
PCB CONNECTOR/S 16P L |
EX07N41277 |
Jumper Wire
Ref#
Description |
MFR.
Part No.
J1 |
JUMPER WIRE 7x10x7 |
WX01070710 |
J2 |
JUMPER WIRE 7x12x7 |
WX01070712 |
J3 |
WX01070710 |
J4 |
WX01070710 |
J5 |
TUMPER WIRE 7X9MMX7 |
WX01070709 |
J6 |
JUMPER WIRE 7x7x7 |
WX01070707 |
J7 |
JUMPER WIRE 7x6x7 |
WX01070706 |
J8 |
JUMPER WIRE 7x7x7 |
WX01070707 |
J9 |
JUMPER WIRE 7x14mmx7 |
WX01070714 |
