Galaxy
DX Radios DX949
Channel
Select PCB EPT094920Z
Trace
Layout
Ref.
No.
Description |
MFR.
Part No.
Channel Select PCB 87.5x48x1.6tmm |
EPT094920Z
Channel Select PCB Complete with Components |
#MT-145F-P03 |
Ref.
No.
Description |
MFR.
Part No.
R202 |
CHIP/F/R (SMD) 1K OHM 0.1W |
RCY011024Z |
R203 |
RCY011024Z |
R204 |
RCY011024Z |
R205 |
RCY011024Z |
R206 |
RCY011024Z |
R207 |
RCY011024Z |
R208 |
RCY011024Z |
R209 |
RCY011024Z |
R210 |
RCY011024Z |
R211 |
RCY011024Z |
R212 |
RCY011024Z |
R213 |
RCY011024Z |
R214 |
RCY011024Z |
R215 |
RCY011024Z |
R216 |
RCY011024Z |
R217 |
RCY011024Z |
Ref.
No.
Description |
MFR.
Part No.
Q201 |
TRANSISTOR(SMD) 2SC2712GR-TE85L |
TY2SC2712G |
Ref.
No.
Description |
MFR.
Part No.
D1 |
DIODE 1N4148 |
ED1N04148Z |
D2 |
DIODE 1N4148 |
ED1N04148Z |
Copper Side |
M/C 0.039UF 50WV K |
CM0503935Z |
Ref.
No.
Description |
MFR.
Part No.
J1 |
PCB CONNECTOR/S 2P |
EX07N48234 |
J2 |
PCB CONNECTOR/S 5P PH=2MM |
EX07N48222 |
J3 |
PCB CONNETOR/S 3P PH=2MM |
EX07N48350 |
J4 |
PCB CONNECTOR/S 3P PH=2MM |
EX07W48824 |
J5 |
EX07N48350 |
J6 |
PCB CONNECTOR/S 4P PH=2MM |
EX07N48490 |
J7 |
PCB CONNECTOR/S 2P PH=2MM |
EX07N48223 |
J8 |
EX07N48222 |
J9 |
EX07N48223 |
J10 |
EX07N48223 |
J11 |
PCB CONNECTOR/S 10P |
EX07N48209 |
Ref.
No.
Description |
MFR.
Part No.
ROTARY SW GPS-0501 |
EWRT32000S |
