Galaxy DX Radios DX94HP
Channel Selector / Frequency Counter PCB (EPT99HP20A)
Part Layout Top View
Trace Layout Top View
Trace Layout Bottom View
Parts List
Ref#
Description
MFR. Part No.
ROTARY SW/DX-98HP EPT99HP20A�
#T-149D-P03
EPT99HP20A
EPT99HP20A
Resistors
Ref#
Description
MFR. Part No.
R5
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R6
CHIP/F/R (SMD) 470 OHM 0.1W
RCY014714Z
R7
CHIP/F/R (SMD) 100 OHM 0.1W
RCY011014Z
R9
CHIP/F/R (SMD) 330 OHM 0.1W
RCY013314Z
R10
RCY011014Z
R11
RCY011014Z
R12
RCY011014Z
R13
RCY011014Z
R14
RCY011014Z
R15
RCY011014Z
R16
RCY011014Z
R17
RCY011014Z
R18
RCY011014Z
R19
RCY011014Z
R20
RCY011014Z
R21
RCY011014Z
R22
RCY011014Z
R23
RCY011014Z
R24
RCY011014Z
R25
RCY011014Z
R26
RCY011014Z
R27
RCY011014Z
R28
RCY011014Z
R29
RCY011014Z
R30
RCY011014Z
R31
RCY011014Z
R32
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R33
RCY011034Z
R34
CHIP/F/R (SMD) 100K OHM 0.1W
RCY011044Z
R35
RCY011034Z
R36
RCY013314Z
R37
CHIP/F/R (SMD) 39K OHM 0.1W
RCY013934Z
R38
RCY011034Z
R39
RCY011034Z
R40
RCY011034Z
R43
CHIP/F/R (SMD) 820 OHM 0.1W
RCY018214Z
R44
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R45
CHIP/F/R (SMD) 27K OHM 0.1W 5%
RCY012734Z
R46
CHIP/F/R (SMD) 15K OHM 0.1W 5%
RCY011534Z
R47
CHIP/F/R (SMD) 6.8K OHM 0.1W
RCY016824Z
R50
CHIP/F/R (SMD) 4.7K OHM 0.1W
RCY014724Z
R51
RCY014724Z
R52
RCY013314Z
R53
CHIP/F/R (SMD) 47 OHM 0.1W
RCY014704Z
R54
CHIP/F/R (SMD) 220 OHM 0.1W
RCY012214Z
R55
CHIP/F/R (SMD) 1M OHM 0.1W
RCY011054Z
R56
RCY011024Z
R57
RCY011034Z
R58
RCY011034Z
R59
RCY011034Z
R58
RCY011024Z
R62
CHIP/F/R (SMD) 0 OHM 0.1W
RCY010004Z
R313
RCY011024Z
R314
RCY011024Z
R320
RCY011024Z
R423
RCY018214Z
R12
RCY011024Z
R13
RCY011024Z
R14
RCY011024Z
Capacitors
Ref#
Description
MFR. Part No.
C1-1
E/C 100UF 16WV Z
CE0161077Z
C1
E/C 100UF 16WV Z
CE0161077Z
C2
CHIP/C 0.01UF 50WV K X7R
CK1103AB5X
C3
CK1103AB5X
C4
CHIP/C 0.1UF 25WV Z Y5V
CK2104AB7R
C5
CK1103AB5X
C6
CK2104AB7R
C7
CK2104AB7R
C8
CK2104AB7R
C9
CK2104AB7R
C11
CHIP/C 4.7UF 16WV Z Y5V
CK5475AA7R
C12
CK2104AB7R
C13
CK1103AB5X
C14
CK1103AB5X
C15
CK2104AB7R
C16
CK2104AB7R
C17
CK2104AB7R
C18
E/C 100UF 16WV Z
CE0161077Z
C19
E/C 100UF 16WV Z
CE0161077Z
C20
E/C 100UF 16WV Z
CE0161077Z
C21
CK1103AB5X
C23
CHIP/C 10PF 50WV D CH
CK1100AB2A
C24
CHIP/C 1UF 16WV Z Y5V
CK5105AB7R
C25
CK2104AB7R
C26
CK1103AB5X
C27
CK1103AB5X
C28
CK2104AB7R
C29
CK2104AB7R
C30
CK1103AB5X
Ref#
Description
MFR. Part No.
VC1
TRIMMER/C (SMD) K20PF 3.8p
CV038200AY
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
I.C. (SMD) (RANGER) 48PINKHT48R50A-48
YNRGFC04SP
IC2
I.C. (SMD) (PHILIPS) K74HC161D 16PIN
YNPHHC161D
IC3
I.C. (SMD) (JRC) KNJM78L05UA-TE1 3PIN
YNJR78L05Z
Transistors
Ref#
Description
MFR. Part No.
Q4
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q5
TY2SC2712G
Q7
TY2SC2712G
Q8
TY2SC2712G
Q9
T/R (SMD) 2SC2714Y-TE85L
TY2SC2714Z
Q10
T/R (SMD) 2SA1162GR-TE85L
TY2SA1162G
Diodes
Ref#
Description
MFR. Part No.
D12
DIODE (SMD) K1SS355
EDSS00355Y
D13
DIODE (SMD) K1SS355
EDSS00355Y
D18
DIODE (SMD) K1SS355
EDSS00355Y
D19
DIODE (SMD) K1SS355
EDSS00355Y
D20
DIODE (SMD) K1SS355
EDSS00355Y
D21
DIODE (SMD) K1SS355
EDSS00355Y
D22
DIODE (SMD) K1SS355
EDSS00355Y
D23
DIODE (SMD) K1SS355
EDSS00355Y
D24
DIODE (SMD) K1SS355
EDSS00355Y
D29
DIODE (SMD) K1SS355
EDSS00355Y
D30
DIODE (SMD) K1SS355
EDSS00355Y
D31
DIODE (SMD) K1N4148
ED1N04148Y
D32
DIODE (SMD) K1N4148
ED1N04148Y
D321
DIODE (SMD) K1SS355
EDSS00355Y
Inductors
Ref#
Description
MFR. Part No.
L1
CHOKE COIL (SMD) G100UH TF J
YCTLI1073F
Switches
Ref#
Description
MFR. Part No.
ROTARY SW
KGPS-0501
EWRT32000S
SW CHASSIS
MTDX55042X
Crystals
Ref#
Description
MFR. Part No.
X201
CRYSTAL HC-49/U K4.500MHz
EYCAP04500
Connectors
Ref#
Description
MFR. Part No.
J201
PCB CONNECTOR/S 10P PH=2
EX07N48209
J202
PCB CONNECTOR/S 3P PH=2MM
EX07N48350
J203
PCB CONNECTOR/S 4P PH=2MM
EX07N48490
J204
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
Copyright © 2007 CBTricks.com
