Ranger (Texas Ranger) TR-966
Clarifier Mod
There is two diferent ways to open up the Clarifier use the one that you like best.
Method #1
Method #2
NOTE:
As with any mod exercise a great deal of care !!!!
Due to the placement, size, and close proximity of the surrounding traces.
If done wrong you could destroy the PCB or components.
If you have even the slightest doubts or the proper equipment , it would be wise to have someone else you trust perform the mod for you.
SO TAKE YOUR TIME AND DOUBLE CHECK YOUR WORK!!!!
Note:
After doing the Clarifier mod or clarifier range mod you will need to realign L20, L21, L22 but not VR7 because the clarifier mod eliminates VR7 from the circuit.
Copyright © 2006 CBTricks.com
