peak and tune
if you do in fact have the magnum s380, it will do all of 80w, maybe a little more with the proper tune. if you have the regular magnum s3, expect no more than 60w, max PEP..... and that's with a proper tune.
well i ordered it from a place that i did not know the rep of so i told them to keep it stock. ill do the channel mod myself. will it do 80 watts out of the factory?
right out of the box....... you should see numbers in the neighborhood of 70w-85w, max. given your feedline and antenna is good and your SWR's are of a low nature. i had one tuned by preacherman...... it was a swinger! a shade over 100w max PEP.
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
