President P300
HomerBB
Jan 4, 2009
3,941
2,682
273
69
Rogers, Ar
A friend gave me an old P300. It's dirty, works, and appears to be untouched internally. The SSB appears to be aligned. The question is, what about this radio? Good, bad, junk, ok? What can it be made to do? Any performance potential?
The only thing I've found on it online is the tuning vr's or "L" pots.
Thanks
what PLL chip does it have in it?
i think those are an MB8719 chassis.
if that is the case, then, yes, it is a very good radio worth keeping and fixing up.
good luck,
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
