Wouxun KG-UV3D Software Questions
kj4bgq
Jan 9, 2011
66
Does anyone have experience programming the Wouxun KG-UV3D via software? Specifically, I want to know what is the purpose of the Frequency Mode, (A & B), under the Optional Features menu. Are the settings channel specific or band specific? If I program via the main page, do I even need to change the settings for the A & B modes?
KJ4BGQ
:bored:
KJ4BGQ
:bored:
Set "Channel Display Way" the way you want it... AND set the "Step Frequency" to that appropriat frequency steps.. say 5 khz, otherwise when you upload a frequency into memory, you may get an "out of range error"
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
