2510, Bulb burns out!!!
15minigrass
915
29
28
52
I just installed a used wheat lamp its really bright. I didn't use the other white wire for ground but soldered the ground end to an existing can on the board. but 2 days later, poof, Not working. Im thinking if I should add a resistor inline. I tried one time adding resistor inline for 12vlt applications and it heated up.
Help!!!!
Help!!!!
Not sure about the 2510; but I know that Cobra/Uniden radios go through a resistor so that it tones down the bulb strength. In fact, I did what you did awhile back and put the bulb getting direct 13.8v into a Cobra meter. Melted that meter within two days and had to replace it!
lol!
Live and learn.
I would go back into the radio and find out where the "+" wire for the original bulb was soldered - and attach it there.
Before you melt the meter like I did . . .
lol!
Live and learn.
I dont think its the heat that killed it, I think the extra voltage is the prob. Even if I install an LED, Id still need a resistor in line thou.
Thanx for the info guys.
OK, thanx guys. Will keep ya posted. Looked so good to see the meter lit up, then this morning, kaput!!! :lol:
Will look around. Aloha james.
Write your reply...
