How do you hook up a....
Preamp.
Behringer Mic 2200. $100/new or $65/used. Best bang fer buck. A dedicated preamp is always better . . .
Does it have a headphone jack so you can hear your audio?
Hmmm its got a compressor....wasn't that what gave old broadcast news that "sound"?
I've read Robbs posts on HiFi setup an got ALOT of useful info from it, I have the HIFI rack going but use no mixer. I run
Nady sp5 mic-new $20.0 good starter mic 50-1200hz
To- Art Tube Preamp-used $39.0(upgraded tube)
To-dbx 131eq-used $39.00
To-Behringer Compressor-used $40.0
All useing XLR cable(balanced) straight into mic jack.
I run a 148gtl thats been modded to pass wideband audio, sounds great
May add a effects prossesor to add a hint of reverb and a exciter to enhance overall sound.....:tongue:
Awesome...post a pic. :thumbup1:
For the radio operator, Its more than good enuff;)
Does it have a headphone jack so you can hear your audio....I want to be able to hear how I sound and be able to make adjustments......if it is a stand alone it should have one?
You can use your radios talkback, if it has one or to get a true audio sample of your sound you'll need a second radio, no ant. hooked up.
Just have it nearby so you hear yourself, you may need to turn your rf gain down a bit. hope this helps
Yup. Put a dummy load on it too. Plug in a nice set of headphones to that radio's external speaker jack. Turn down the RF Gain on it too.
Write your reply...
  • @ W4KVW:
    I mete KZ4RR there is 2013 for the 1st time & we live about 50 miles apart & had talked for many years. Traveled halfway across the country so we could finally meet. LOL W4KVW EM80wg
    Lee/KZ4RR will be thr at XENIA this year again...will be great to see him...We work almost every morning on 6m SSB
  • @ W4KVW:
