Baofeng UV-3R MKII Review - 2m/440Mhz Mini HT
Does the BAOFENG UV-5R come with a dual band antenna? the spec's say it does, but the package contents lists the antenna as 1 x Antenna 400-480Mhz
Originally Posted by WA6MHZ
Just programmed my UV-3R+PLUS for the 222 band!!! Yes, with a simple software mod, the radio now covers 222 too and transmits full power there.
But I wasn't able to key up any repeaters as the antenna is for 2M and 450 only. I gotta score a TRIBAND rubberduck antenna for it now!
Mole - have you tried to get the 220mHz band on your Baofeng+3?
That would only be uber-cool if you can repeat what he did!
Join the UV-3R and UV-5R Yahoo user groups.
There are discussions on this topic. I wouldn't expect much performance or efficiency on 220.
The gentleman's claims of full power output sounds dubious.
I'll try it on my radio tonight and report back after testing power output into a dummy load.
I performed the 220Mhz mod today. It didn't matter which way I did it, I got no power output on 220. The radio did transmit, but didn't have any meaningful wattage.
I've summed up some of the info from the Yahoo Group - although there is still a lot of back and forth. You can click the links to see the whole debate, but I think one guy summed it up best: "So it WORKS on 222, KINDA!"
Brick O'Lore: Baofeng UV-3R: Expanded Frequencies 222 MHz
The post also includes a link to some software that will modify your .ini file for you.
Any new tech should love this as a viable option.
Low cost and very small.
If the dog should eat it; then you can't cry as hard as you would if it ate a Yaesu!
2 watts and a repeater = new Ham that got on 2m for a lot less money than I did.
What will HRO do now?!?
It's my first radio. I have since learned you do get what you pay for with this radio.... The covers for the cable connectors keep coming off, I ended up loosing mine at the dairy festival. In Georgia, my landyard pulled apart (very cheap lanyard. I got a rope type lanyard and connected to the end connector of the original one and it's a lot better! 2 Watts is very limited, and on top of that, I noticed on field day, if the battery gets close to 1/2 mark, I can't hit the repeater and the voltage drops. Keep a full charge and your fine.... Also, built a ground plane antenna for it using a 20 inch stinger and 4 20 inch radials. Makes a HUGE difference! Everyone says it puts me out there a lot better! Nice radio for a first time ham, but soon after you get the bug to go with something that has a LOT MORE WATTS ;-) We're talking HF range....
  • @ Tim Chambers:
  • @ AWP:
  • @ wavrider:
    sea que sea que,
