Today I switched out my Wilson 1000 with a Siro 5000 (Mag roof mount) and there is no doubt the Siro flat out outperforms the Wilson. It was obvious that I could hear at a greater distance than I could hear with my Wilson. I am sold on Siro. .
nice to see you guys over the pond have finally realised what us Europeans have known for at least a decade, that the cheap Chinese built Sirio's, easily outperform and are cheaper than the made in the Usa pishy Wilsons that are seriously overpriced, just like k40's before them.
Won't be long before your ready to hand over the world's largest superpower status to the Chinese. oh by the way, Chinese cuisine is top quality shit too,you guys will love it![]()
Let me ask you a potentially stupid question if I may. Will the magnet mount from a Wilson 5k work with the Sirio 5k? In other words, can I screw the Sirio onto the Wilson mag base...sorta plug & play or would I need to buy a Sirio mag mount?
Sorry if this is a silly question but over on this side some of us aren't as familiar with Sirio as with Wilson/k40
regarding the later part of your post, perhaps we already have done that.....damn shame:sad:
Do you guys think a wilson trunk lip mount would hold up better with the sirio on it versus the wilson mag mount?
as posters have mentioned, yes it will fit, but i'm not so sure the wilson will be as strong as the sirio mag 145pl at high speeds with 4000/5000 series whips.
on the plus side, the sirio high power/megawatt/performance series being pl type fittings will fit any so239 type mount.the mag 145 pl is plenty strong, easy to change/upgrade coax/service and works well, but like all magmount/antenna combinations can be a tad touchy of rf feedback/common mode problems depending on radio/linear used. there's no substitute for a properly grounded mount, but for the most part with sirio's we've had few problems.
the one thing to be wary off when dealing with sirio antennas is their power handling claims,grossly over exaggerated by most peoples terms, but typical of all italian companies when it comes to dealing in watts,i'd be wary off putting more than 300w in any of them, but as they are such good performers 300w is plenty, i've worked the states,canada, most of s.america, the carribean,s.africa and australia all from mobile and many on substantially less power than 300w
put it this way, a superstar 3900,president jackson,president grant or lincoln (take your pick) rm kl203 and a sirio antenna and you'll work plenty, you don't need fancy gear and no idea to work the world, basic gear often does it as well if not better than expensive gear that most folk don't have a clue how to use anyway.
it probably would be more secure, but if its the type i'm thinking of you have to make sure those two grub screws break the paint and touch the metalwork properly, even then it can be touch and go with trunk/boot mounts as they don't always have a solid connection to the rest of the bodywork.
i would always prefer the drill through the bodywork type mount, both for performance and strength.
something like this:
