Roger Beep Heaven
i like the 2950 beep. If you extend it a bit, it sounds really nice. short burst on thr 1st beep and extended beep on the last.
want to know what's even cooler than the 2950 beep? hook a 1/4 plug on the cw side rear and flip it closed endless beep until you open the circuit. Add that plus 2kw on .025am;)
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
