Cobra 135 doesn't transmit
Turbo T
Certified CB Rambo
Feb 2, 2011
963
142
53
Today I picked up (for free) a Cobra 135. This is a 23 channel base rig. So far it powers up and receives, but does not transmit.
I've tried a few different mics, one of them I wired for the radio per the instructions on CB tricks...that didn't work. I tried the mic from my Uniden 510...that didn't work either. (the same mic I just wired worked on the 510 though)
I tried jumping pins 1 and 3 as if I didn't misread the schematic on CB tricks, this should have made the radio go into TX mode....but it didn't.
What else can/should I look for?
Thanks in advance.
The key up of this radio is done by the use of a transistor, 2SA562, a "common" (good luck finding it) PNP switching transistor. Denoted as Q24, it is directly controlled by the key circuit of the microphone.
I have found this to be a common fault of circuits of this type.... :oops:
73 mechanic
Thought I'd give an update. I found the PA system works on it. So at least I'm pretty sure I have the mic wired right.
I do hear a little small popping sound thru the internal speaker when the mic is keyed.
Mechanic, is there any thing I can do to check the transistor you suggested might be bad?
A transistor checker would help or you could check junctions with a VOM or DVM. I would try to find a replacement if possible, Mouser would be a good start and they have no minimum quantity. Rat Shack had these once but no more.... you could rob one from a parts radio if you have one.
By the way this base is a winner and is well worth the effort to repair! With a single crystal swap and adjust the voice lock spread, you will have over 46 channels and all in betweens! :thumbup:
There is a diagram on CB tricks....
73 mechanic
73 mechanic
Mechanic,
I do not have a transistor checker. I do have a multimeter. Perhaps there's some way I can check for voltages on the legs to see if they're what they should be, with the multimeter?
As for a replacement, the only parts radios I have are a Realistic TRC-422A, though it doesn't RX or TX so who knows if it has any useable parts. That and I have an old Royce 1-612 that I could perhaps rob a few parts from, if it shares any identical parts.
I checked Mousers website and they show no matches found for "2sa562". I did search around online and found this on eBay, is this the correct transistor you speak of?:
20 PNP Plastic-Encapsulate Transistor 2SA562 A562 TO-92 | eBay
As for your last comment, yeah, everything I read about the Cobra 135 says it was top of the line....back in the mid 70's! And that it sold for over $400....I did an inflation calculator, and that would be just over $1600 in today's dollars! :ohmy:
But of course I was "given" this radio for free, by a CB repairman who was "just going to chuck it in the trash" (along with the Royce and Realistic I mentioned). I didn't get a power cord, or a mic for it. But if anything, I do want to bring it back to life and perhaps keep it in my little collection, even if it is just a 23 channel radio. It's just a nice looking piece.
Write your reply...
