FT-7900
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
Anyone have a photo of the back of the face plate to see how it mount's? I really dont like that junk plastic cage think to mount the face and was wondering if it has a Threaded type hole like my FTM-350AR.
I don't recall seeing any threaded holes on the back of my FT-7900R fascia. I can confirm later when I get home if no-one else has confirmed this in the meantime, but from what I remember there isn't one.
The beauty of that plastic caddy though is that you could always fix a nut on the back of it to make it threaded and use that on the mount you wanted to use.....
If you have time today couldja post a picture of the back of the face ?
★ Sent from my Droid★
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
