Monitor Your Ham Radio With An Oscilloscope (VIDEO)
Very cool. I run a Yaesu FT-101ZD in the shack with a YO-901 Scope attached. I have it setup to monitor my output and I can also use it as a band scope to find signals.
I have channel 1 monitoring my tx signal and channel 2 monitors my receiver IF so I can look at the signal of whom I am talking too. My Kenwood TS-820S has the rx IF OUT port.
If I would hook it up to the FT-901dm I am repairing then I could monitor incoming sigs as well but the 101zd wont work that way with the YO-901.
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
