remember that increased bandwidth is not necessarily a good thing when it comes to how well an antenna "gets out".
my dummy load has a flat 1:1 SWR from 1 to 30 mhz but it doesnt get out for squat!
antennas only have one specific frequency that they are resonant at (you guys know what im getting at, lets not throw red herrings in here!)
some antennas SWR curve is much narrower than others, but generally an antenna with a sharper curve is a more efficient radiator than one with a broad SWR curve.
Yeah. Marconi noted that when he added a ground plane on the A99(I think), that the A99 indicated that it had a more pronounced swr/vswr(?) curve whereas before the ground radials where added it pretty much had a relatively flat swr curve. That right there tells me that ground radials are supplying the A99 with a nominal but more effective ground plane than if it was using the coax shield,mast pole,or neighbor's occasional wandering dog.
I intend to adjust my A99 to one resonant frequency and if I want to go band surfing in the neighboring free bands then I'll use my MFJ-971 just for that. I'm pleased with the results I have so far after erecting my A99. You see my stated radio checks I've gotten a few posts back and here's another radio check. Later last night another CB base operator 18 miles away gave me a 5 1/2 s-unit reading.
Again I sounded good and clear to him.
Last night I and my brother had a discussion over the airwaves about the possible variance of S/RF receive meter readings on different radios. He tried three different radios as he gave me dead key and pep readings that I sent using my 4 watter Galaxy DX-959 coupled up with my A99(tuning rings at 37').
His radios he used in the test and S/RF readings
Cobra 89GTL: 5 1/4 s-units dead key
Royce base station(find out model afterwards) 3 1/2 s-units dead key
Royce 1-604 NOS/NIB(DTB RADIO tuned): 8 1/2 s-units dead key.
His first two radios haven't if ever been under the care of a reputable,good tech. I don't think they've ever been tuned. I do know that the his Cobra 89GTL has been hacked half to death by a self appointed radio technician(sounds awful/AMC clipped). The Royce base station's receive doesn't receive that strong.
The Royce 1-604 he has that I gave him that I had DTB tune,I feel confident that the 1-604 is tuned to perfection. The 1-604 has a auto RF AGC circuit in it so I don't know if that will change his readings on different distance OP's. I know that my 959 that is DTB tuned and has the receive mod done to it. My 959 shows my brother's radio signal on my Galaxy's S/RF meter at an average of 7 1/2 s-units for all three of the radios he used that I described. There people in my neck of the woods that think that radios come tuned and aligned from the factory. I am quick to try and educate them that the factory ballpark tunes them and/or hamstrings them such as in the case of my Galaxy DX-959 but are't tuned for optimum efficiency.
You can lead a horse to water but you can't make him recite Shakespeare.
