magnum s980 175?
sitting duck 616
102
8
28
42
des moines, ia
So i bought this magnum is this a joke or what is the deal here
I thought the s980 has 80 watts but then it has the heat sink and the seller is stating its a 175 watt radio so where do i get more info on this set up..
That radio is no joke. So long as someone hasn't put their hands into it to modify a radio than requires nothing done to it to begin with, it should work very well for you. Fine as is.
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
