I appreciate all the help you have given meAn NOS relay will probably work just fine. If it's cheaper, it makes sense to go that way.
We only came up with the substitute board when the prices we were seeing for the original got out of hand.
Bargains do go by on Ebay.
Just gotta act before they go away.
It also saves me the trouble of changing relay that was workingYou mean this pic?
This is just an example of how to get by with just one of these relays. The receive signal and your barefoot-standby transmit power both go through this jumper. Would be going through the preamp relay if it works. And that's the reason to bypass it, when it starts to cut out.
