Wanting to build an experiment with antennas
Richard S
New Member
Jun 4, 2020
4
64
A few years ago I was on here and somebody had a file with antenna basics and how to build different kinds of antenna does anybody have or know where I can get this file again thank you
Do a forum Search at the top right corner of the front page.
Good, I see you found something.
Reactions: sp5it
There are some YouTube videos that might get you started in the right direction or give you ideas on things to try, antenna building is pretty simple with wire or aluminum poles, the dimensions are critical and it gets more complicated with matching baluns, a good first antenna is a 1/4 wave ground plane
Welcome Richard, You might be able to Google the ARRL handbook. They have tons of info on antennas.
Write your reply...
  • @ Crawdad:
    Will do Gary, thanks! Hopefully see you Friday next.
  • @ Crawdad:
  • @ W4KVW:
    Rock Stars ROCKS!
  • @ Crawdad:
    Looking forward to it Gary!
