I need some help
Griza
New Member
Dec 19, 2022
9
Hello, I have a question if someone could help me. My grandfather passed away while ago and I am deciding to sell his cb radio system. Its a Gray solid state 200-watt amp and I have no idea what it's worth. Please let me know
Thanks
Graham
Thanks
Graham
It would really help if your picture was a much higher resolution, and you had some pics all around and inside.
ya for some reason its only coming up small.. i took it on my s21 ultra. I am goin to do it again
griza,
the two most important pieces of information you can provide that will allow us to give you a realistic estimate of the amp's value, are a good pic of the inside, and a test that it actually works.
That particular amplifier is a hot rod. Not a big hot rod, but it hovers around or just past the red line, in a manner of speaking.
Bearing in mind we don't know how 'original' it is on the inside, I'm just offering an educated guess.
It uses an unregulated power supply. The DC voltage that it puts on the transistors is well above the rated limit. This will work just fine for a while, so long as no major stress is applied to it. But if it is keyed for a little too long, or with a little too much drive power or with a bad connector/coax in line with the antenna, things break. Naturally this is true for all linear amplifiers. But this one has a smaller-than-average safety margin.
If it still works okay, we can be sure of one or the other of two things: Either the guy who used it understood the limits and respected them, --OR-- it has very little mileage on it. No odometer to read off to tell that.
And if it has been modified since it was built, all bets are off making predictions about it.
it's sat in my closet for over 10 years, it was my grandfathers, there is large amount of dust on the board, I would like to clean it off before turning it on. you have and recommendations on a product to wipe it down. I'll send some pics inside once its cleaned, and I'm almost 100% sure it will power up. I know it was running just fine when he passed
Just used an air gun to clean it out. still haven't plugged it in, should I get my voltmeter and test it before plugging it in, and I added a pic of the power supply
Ya i just nooticed that when i posted it too. you are talking about that red wire that is connected to the base of the amp? what is that wire for? im curious to know
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
