How to disable talk back Stryker 655hpc
Truck
Dec 18, 2012
68
3
18
KY
Love these new radios but the talkback will not shut off completely it will only turn down and that causes problems with squeal when using a power Mic
Been working with Shawn at Stryker. Here is the fix. Worked great of course the final touch up would include heat shrink
The talkback control is on the top just to the right of the name Stryker, it's the "mon" control.. Here is what Stryker says about their talkback control. Should be pretty simple.
  • Variable Talk Back ControlThe infamous talk back squeal is virtually eliminated with our independently controlled talk back circuitry. The Stryker CB radio operator can adjust the volume to the perfect level as operating conditions require. Best of all the user no longer has to turn down the microphone gain to stop the annoying squeal that is often the result of poor design or cost cutting at the production level.
  • 2 Mon: The variable Mon control (talk back) is used to monitor your ownvoice.This can be used to compare different microphones. To increasethe volume of the talk back rotate the control clockwise. To decreaserotate counterclockwise. To turn off the talk back rotate the controlcompletely counterclockwise.
    AKA- UDX122
  • @ nfsus:
    RFactive has left the room.
