It won't. I just got two.I bet the 66" would work. But get them quick. They are discontinued.
Im not mad, ill use them on my other Wilson antennas
If you have 2, you can have the rig soldered and have the stinger you want. Solder close to the tip, not the bottom. I did it once and worked fine.It won't. I just got two.
I have a Sirio 5000 on my old Wilson 5000 mag mount, no problem. Although the Sirio mag mount has a bigger diameter.I've wondered if the Sirio will work on a Wilson roof mount as well. I've got several, older, Wilson 1000 antennas and one of the newer 5000s. I would really like to know if a Sirio would fit properly on the Wilson roof mount.
