TA7205 10 pin SIP find
doc john
New Member
Sep 1, 2024
10
6
3
74
Ontario Canada
I'm over the moon this afternoon! Went to my local electronics parts supplier this morning to pick up several items and asked if they had any TA7205P 10pin audio chips. I had previously checked all the usual sources only to come up empty handed. They said are you sure there aren't any on the wall and we went together to check. There they were... 6 in a bag on the wall. I couldn't believe they were there. Needless to say I bought all of them! I'm stoked!!
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
