6666PRO /QT80 with uniden bc906w wireless mic
jrd426
Well-Known Member
Sep 5, 2018
259
195
53
57
Hey Guys, has anyone here tried the older uniden wireless mic on a q6pro or qt80 ? I did some searching about this before posting here and did find a vid where the fella disconnects the original wire from pin 2 and takes the wire from pin 4 and puts it on pin2. Original wire from pin 2 stays unused. Anyone have any experience with this? Ty! Happy Friday
Reactions: FlyBoy50
This will be interesting because I have a Uniden wireless mic.
Reactions: jrd426
Uniden wireless mic wires are as follows. So if you figure out the wiring of your radio just put what needs to go to each pin.
Pin 1 - modulation
Pin 2- RX
Pin 3-TX
Pin 4- Audio from receive
Pin 5- Common
Pin 6- 8v+ DC
Reactions: FlyBoy50
Been thinking of trying it. Just want to be sure I don't screw up anything on the q6p :-
Let us know how you make out. I would like to try but I have too many irons in the fire at the present time. But I did print out Knee Biter's wiring instructions. I also got a renewed interest in my White's metal detector that's been setting on the shelf for years, but that's a Spring time project ! PS. The Uniden Wireless mic might not modulate as good as the stock mic. I checked my Q6-PRO Modulation on my Dosy meter in SSB and it was really Cranking !
Reactions: jrd426
There is a mod for opening up the hole in the Uniden Wireless mic somewhere but I don't remember where it is.
Write your reply...
