Sams PhotoFacts Collection
Just trying to keep CB alive one scan at a time... Dan
Thanks for your efforts Dan, and all of the members who help out, this has been one of the core goals of the forum since the beginning and it great to see people helping others.
All of your efforts are appreciated.
In that case, I could also use one for the robyn sb-520d and the cobra 2000gtl.
Here is the info for the Robyn SSB-520D and the Cobra 2000... Dan
Hi, Dan, it's me, the pest, again! I am in need of the Sams for the Sears RoadTalker 40, model 934-38260700. Can't find one anywhere.
Thanks in advance...
Justin B.
KI5GKD
Reactions: AudioShockwav
Justin B.
KI5GKD
Hi Justin.....you're not a pest by any means...let me check and I'll get back to you...Dan
Back at ya Justin....turns out that radio's info was already scanned...here ya go...Dan
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
