DX 949 Sound/speaker failure?
WT 10
New Member
May 8, 2024
4
Talking dx on my recently acquired 949. It's going great and I'm making loads of contacts on 12 watts. Suddenly the sound cuts out. Still receiving because I see the needle moving. Transmits too...just no sound. So bummed. Any ideas? I appreciate you all.
When you say it's transmitting good, do you mean it is transmitting with audio still? Or is it just transmitting a dead carrier ? Does it have a mic like a Cobra radio where there is no receive audio when the mic isn't plugged in ? If so it could be a mic wiring problem.....
When I keyed the mic and spoke, the meter showed the telltale signs of active broadcasting, except that I could hear othing from the speaker. The meter also showed that the radio was receiving. This all occurred very suddenly. I had been operating for an hour or so.
We just had another guy with a similar issue with a connex 3400, similar board and also made by ranger. He had a cold solder joint at one of the electrolytics. From the audio ic, chase the path back to the speaker jack.
Or as @Shadetree Mechanic stated the speaker jack gets dunked up as well.
Reactions: BC Coyote and WT 10
Very common problem with Ranger products. Remember, Galaxy and Connex are just Ranger radios wearing different clothes......
Try tapping the circuit board with something non-conductive and see if you can find a spot where the audio cuts in and out. That will give you an idea where to start looking.........
Reactions: doffo
  • @ Mark Malcomb:
    Hello BJ. Been a long time since I've been on. You doing well? Mark Malcomb
  • @ Naysayer:
    I’m
  • @ kingmudduck:
