When I keyed the mic and spoke, the meter showed the telltale signs of active broadcasting, except that I could hear othing from the speaker. The meter also showed that the radio was receiving. This all occurred very suddenly. I had been operating for an hour or so.When you say it's transmitting good, do you mean it is transmitting with audio still? Or is it just transmitting a dead carrier ? Does it have a mic like a Cobra radio where there is no receive audio when the mic isn't plugged in ? If so it could be a mic wiring problem.....
We just had another guy with a similar issue with a connex 3400, similar board and also made by ranger. He had a cold solder joint at one of the electrolytics. From the audio ic, chase the path back to the speaker jack.When I keyed the mic and spoke, the meter showed the telltale signs of active broadcasting, except that I could hear othing from the speaker. The meter also showed that the radio was receiving. This all occurred very suddenly. I had been operating for an hour or so.
Thank you. I'm going to plug in some headphones after work to see if that works to hear audio.Connex 3400hp low volume
Radio receives good but volume is super low, receive volume and talkback. Turning the volume all the way up makes it decent but not anything like it should be. Any ideas?www.worldwidedx.com
Of course, I will look into all of your other suggestions, as well. Thanks for the help.Thank you. I'm going to plug in some headphones after work to see if that works to hear audio.
Very common problem with Ranger products. Remember, Galaxy and Connex are just Ranger radios wearing different clothes......made by ranger. He had a cold solder joint
