im of the impression that 1/2wgp and 5/8wgp antennas radiate from the middle section of the verticle where 1/4wgp's radiate from the ends or the full length . IF...... if ive correctly understood what ive read could that be why the larger antennas dont need or benefit as much from a choke as a 1/4wgp for CMC's ?
Not really. Any antenna can produce CMCs if it's not tuned correctly. An antenna radiates over it's entire length. That radiation may be concentrated at particular heights/distances from it's feed point, but the whole length is required for it to do so.
as for the sleveing or tubing around the coax below the feedpoint . since its connected to the ground side of the coax why would that stop CMC's ? would using doubled shielded coax (foil and braid) have a similar effect ?
No. That sleeve is a particular electrical length and that length has properties that affect what current happens to be conducted on it. One of the properties of a 1/4 wave length is that it offers very high resistance (impedance actually) to RF at it's design frequency. So, as that current gets to the 'end' of that sleeve it's all used up, gone. Is it really like that? No, but it works as a non-electrical explanation.
in another bid to prove my lack of reading comprehension skills (LOL) arnt antennas with no ground radials (antron/imax/etc.) and antennas with drooping down ground radials much more likely to encounter CMC problems than ones with horozontal full length grounds ?
No. Those radials don't stop CMCs as such. The only thing the 'tilt' of those radials affect is the input impedance of the antenna.
jazz the other guys know im just a cb'er so be easy on me , hahahaha .
just letting you know .
im thinking (the source of many of my problems) that a flat vswr is relative to the bandwith youre measuring it on . doesnt every antenna tune flat at some frequency ? even if its not the one intended ?
Yes to both of those questions. 'Flat' is a matter of definition. What's the upper/lower limits for that 'bandwidth, 2:1, 1.5:1, or 1.2:1? The common standard is a 2:1 SWR bandwidth limit. Is there a "standard" spread for that bandwidth? No, there isn't. Depends on the particular antenna and how/where it's mounted. They are all gonna be different to some extent.
SWR will be 'flat', or very close to 1.0:1 at some frequency. May not be the one you want (seldom is), but it'll be 'flat' somewhere. The 'catch' to that 'flat' SWR is that resonance has nothing to do with SWR. An SWR meter can't tell you anything about an antenna being resonant. It can only tell you the degree of 'match' between the feed line's and antenna's impedances. That 'nice' SWR doesn't, and typically is never close to resonance with out some type of impedance matching device being used. That 'tilting' of the radials from horizontal is a matching device just like a gamma match, or any other such device.
awesome thread guys !!! thanks
i love this technical mumbo-jumbo stuff (means quality/correct information to hams) .
marconi[/QUOTE]
If you will delete that "to hams" part, I agree with you here too. That correctness applies to everybody, whether they like it or not.
Quit 'bad mouthing' yourself! You ain't dumb. There were only two of us who were born knowing all this stuff. I can't tell you the other one is, she'll get mad at me...
