My advice would be to forget the Bird 43 and just buy a reasonably good quality ham power meter rated for the HF bands. This will be a lot cheaper for very little difference in performance on the 10/11m band.
The Bird 43 is one of the most over rated pieces of test gear out there. I don't own one myself but I have access to them and I've tested several of them.
On the plus side it is a very solidly built and versatile meter if you buy lots of expensive slugs but it is NOT some kind of industry standard meter for power measurement. It uses the same tech as a basic CB power meter for measuring power. eg a directional coupler and a simple (uncompensated) diode detector.
i.e. it isn't a proper power meter, it just reads peak RF voltage at the coupled port in a similar manner to how a $5 CB power meter does it. Obviously it is built better and the thru loss and the meter's own 'thru' VSWR will be better (it's good to use to over 1GHz with the right slugs) but there is no high tech magic inside.
Also, I don't really recommend messing with the x10 mods either and here is why.
On a standard Bird 43 the dial is calibrated for operating the diode partly in square law, partly in transition region and partly in the linear region. This makes the scale unique to this operating point of the diode.
Therefore, if you add the x10 mod then you will be operating the diode/meter in the linear region over most of the dial and the scaling will only be 'right' near the top end.
These old meters are bad enough for accuracy across the dial (away from FSD) and if you do the x10 mod this will get even worse on low and mid scale readings.
It's a dinosaur design that compromises the performance by operating the diode in the transition region and this makes it lose accuracy a LOT over temperature on the low to mid scale readings. Don't use it outside on a very cold day LOL!
By contrast a regular ham meter will operate mostly in the linear region and will be fairly immune to temperature changes unless operated on the lowest power range.
Don't waste your money and just leave the Bird 43 to the 'techs' who believe the BS about how good these meters are supposed to be
