Hi. If you use 75 ohm coax, antenna length is shorter ?I have the skipshooter and the firestik 7 foot antennas that i had experimented with out here on my apartment balcony stationary rail mount.
My dumbass forgot that i was useing 75 ohm coax for cb radio and ended up cutting the entire top load off both antennas to get a 1.1 swr and they both reallly get out there and still perform significantly better than the previous wilson 2000 trucker i was useing before.
The top loads on both antennas was about 10 inches that i cut off and even tho theyre both ruined im still useing one with the 75 ohm coax with an swr of 1.1.
