KingCobra_CDX882 said:that is sort of like comparing a vette to a porsche
both are good
but porsche is clearly better
The Porsche is clearly better? :shock:
both are good
My Predator 10K out performs my Wilson 5000 in TX and RXBOOTY MONSTER said:using a mag mount on each on top of a SUV with a few hundred watts going into it . using same radio,same amp,same coax and coax route and same mike . which if either is better at recieving and also transmitting ?
321 watergate city said:Wilson has spent lots of mola to have that antenna tested in a lab buy engineers to insurre it works..
thetnhillbilly said:321 watergate city said:Wilson has spent lots of mola to have that antenna tested in a lab buy engineers to insurre it works..
That looks like a freudian slip. They probably do buy engineers who will agree with the claims they make. I like both my wilson and 10K, but have no real numbers on either. I'm just making the point that wilson's engineers and testers are not impartial. Just because a guy builds his own antennas doesn't mean that his won't match or exceed a factory produced one. Factories can be inhibited by cost vs. profit vs. quality and quality doesn't always win.
321 watergate city said:Where is the facts that a 10k will out perform a Wilson.. Does anyone have this on paper from a test lab.. Or are we just getting the guy down the street with a Cobra 29 to see how many more pounds he's got on ya?? I mean come on he is looking at a 1 inch meter... Wilson has spent lots of mola to have that antenna tested in a lab buy engineers to insurre it works.. So that makes me think that it is pretty slim chance that a guy in his back yard with a welder is gonna build an antenna that will out perform a Wilson... I may be wrong but thats how I see it...
What makes the Wilson 5000 better than the Wilson 1000? Simple, the wider diameter coil. The P-10K has even a larger diameter coil and shaft section.321 watergate city said:Where is the facts that a 10k will out perform a Wilson... Wilson has spent lots of mula to have that antenna tested in a lab buy engineers to insure it works... I may be wrong but thats how I see it...
Master Chief said:What makes the Wilson 5000 better than the Wilson 1000? Simple, the wider diameter coil. The P-10K has even a larger diameter coil and shaft section.321 watergate city said:Where is the facts that a 10k will out perform a Wilson... Wilson has spent lots of mula to have that antenna tested in a lab buy engineers to insure it works... I may be wrong but thats how I see it...
Does a center-loaded or bottom-loaded antenna work better? The center-loaded!
Taking what we already know, it's fair to reason that the P-10K with its larger diameter coil and being center-loaded will perform better.
Remember, the "mula" spent by Wilson was to compare two BOTTOM-LOADED antennas.
Now, back to the original question at hand, as far as a mag-mount antenna goes, go with the 1000 or the 5000.
