Boy, did I screw that up. Interpreted "not showing any ohms" as low ohms, or a short.
What you meant was there was no continuity at all, as if you had not connected the meter's leads.
Oops.
And that's what you should see. No response from the meter at all.
It's time to check each of the four diodes in the rectifier bridge. At least you don't need to unsolder it for that test.
Let's hope it isn't shorted in a way that could feed AC voltage into the DC-only filter cap. Not good for it.
Oops.
