Another thing I would look at,
Usually where there's Fire - there's the smoke - but usually it's the other way around...
I'm referring to what section needed any repair to even get it to work?
IF it's pristine and no scorching - well then we're guessing...but if you have to fix a final or the tuning was way off...knowing the repair history can lead you to the right Bunny Trail and Stop up the Hole before Bugs' n' Friends make more...
So, if the Final had to be replaced, and now the receive quit, well, what else is in line with the Final?
ALC comes to mind - people change the values there in the circuit to "punch down" the clamping effects - so look past the final - into the out-there, the output network. - for is it not using the same input connector?
Elon in making Tesla - used Mel Brooks for a crutch to help people understand the effects of speed, - using a sense of humor
- there's "Ludicrous"
and then there is "PLAID"
Why are we talking about Speed?
Well, it can also apply to troubleshooting conditions; you think are ok, but if not - one has gone back and revisited - even I have caught myself as well as others pointed out - errors done before - it's nothing new.
Just have to make sure
Because? A 142 has SSB mode, so it uses a sense tap for the ALC control - that means it is wired in back there - at the rear panel - in the output network - that uses the same area to tap it's received signal from - so if one works - you know there's two - make sure you can get a signal from that tap off - from that area.
