The "shorty" screwdrivers are a compromise. There are NO easy "fixes" to this when it comes to HF!
If you are after the BIG signal, the if-I-can-hear-'em-I-can-work- 'em, then it takes a BIG, "UGLY"(?), BOOFY (pardon to the Croc Hunter) antenna. And that means a FULL-sized HF antenna. If one must compromise (just can't drill that hole on the new Chevy, XYL will shoot to kill
), then go for the shorty screwdriver. Just don't let "fancy-ness" lull anyone into thinking that "Hey, I can work 160 thru 10 Meters on a pretty, little "shorty" screwdriver that's only 4 feet tall in toto", cuz it ain't gonna happen!!!!
Next time you go out to a hamfest where the screwdriver sellers are, take time to LOOK at one of the little "shorty" screwdrivers and compare it to a FULL-sized unit that has, at least, 16 ga. wire wound at 10 TPI.
That fullsized unit will walk ALL OVER the mini unit! So how do they GET all this coverage with a "mini" screwdriver? They use a "skinny" loading coil wound with #18 or #20 wire that is all but "transformer-wound"! IOW, super skinny wire wound closely on this itty bitty coil!
! So, YES! They
can get up to 160 thru 10 Meter "coverage"..............BUT! the "Q" of the coil is, like..............in the basement! About as sloppy as a 75M hamstick, and I will all but guarantee you, you AIN'T gonna be heard on FORTY meters all THAT well, almost NO chance on 75 Meters, and the odds on 160? Won't even GO there!!
Oh, it will work-----after a fashion. But if you work 40 on one of the mini units, then step up to a full-size screwdriver, it'll make you sick at the difference.
To each his own, and the mini units have their place as does any mobile antenna. Just know the merits of all of them.
Best 73
CWM
