2510 am question
I think I did lower the dk to about 3 watts but then you get maybe 80 or so watts out, no negative swing but still no forward swing. I am thinking still the meter is wack.
Unless you have a High Drive amp, you need to lower the dead key out of the radio down to 2-4 watts...whatever the amp seems to like. Usually never more than 4 watts on a Low Drive transistor amp.
2510's are also known for low factory modulation so try a power mic on it.
Good luck
For a great power mic, use the Road Devil.... seems to work the best for the 2510! (y)
mechanic
Change out that meter. A PalStar or even a Dosy. Just another meter to start the elimination process.
Turner Plus Three's match up really well with the 2510/Lincolns, voice permitting...
i like the tuner plus 3 also . and the tuner super side kick
these 2 mics are the best ive found others ive found still in production
astatic 878
astatic d104m6b
    Greg T has left the room.
