300 ohm feed doublet antenna with coil
If you had put the coils where they are now in the beginning with your 80 meter mono band dipole you would have probably needed less turns in the coils to get a match.
With a 1/4 wave antenna the current peak will be at the feed point and the voltage peak will be at the ends. This is why it all changed so drastically when you moved the coils. The coils have less effect the further out from the feedpoint they are. If you fed it with coax again I believe it would be matched at a lower freq than it was before.
If you try to tune up a short doublet with your tuner tread lightly. Keep the power down and watch the reflected power like a hawk. Things may start to heat up quickly. With the equipment and amount of space you have your original configuration may have been as good as it gets. Nothing wrong with experimenting though. It would be a boring hobby if it was all plug and play.
Ok i unspooled the coils and ran as much as i was able corner to corner of my small back yard... it started to storm so i did not get a final measurement... ill post it...
With a wet antenna i was able to tune 10 to 60meters it looks like i can tune the top part of 80...
WOW just got done testing and trying different bands. The coils i had on where Messing it up BAD!!!
i was still to lazy to get a total length of the antenna but i cant tune 60 and 80 so that's a win...
comparing it to my Imax 2000 on 10, 12, and 15 meters
10 and 12 are have no difference 15 on the other hand is night and day from the Imax my friend can hear me so much more on the balance line antenna... i was kind of surprised on that...
Good deal. The exact length isn't critical. As long as the legs are the same length and you're in the ballpark of a half wave dipole.
  • @ W4KVW:
  • @ W4KVW:
