35, you promised to test the A99, but the weather was bad.
Marconi. you're so full of shit it oozes out your ass onto the causeway
2010, my momma dear tought me this: "...if you haven't got anything to add or you can't be nice with your words, don't say anything at all." :wink:
This is just my opinion on the subject. I think most of us here know what is typically on your mind, but what is your opinion of the subject being discussed?
Be nice! *Don`t do it*
its not my idea eddie, im just pointing out that the a99 always has a short counterpoise unless you dismantle it,
i don't subscribe to the idea that just because some people claim a 1/2wave can work with a short counterpoise even if that is true it also means we don't need to bother about common mode currents on the coax,
it matters not how little counterpoise you can get away with and still have a working 1/2wave,
common mode current does not say "hey ho chaps lets stop at 1ft from the feedpoint"
i know from experience that a99 can suffer from cm currents that whine in pc speakers, burn your lip, turn touch lamps on and off, cause tvi,
adding radials a fork handle and a properly wound choke has fixed the issue and increased signal strength a little on multiple local installs.
.......And my momma taught me this. During your life you will meet people that are nice, people that are mean, people that are courageous and people that are cowards but the ones you ought to avoid are the one's that believe any kind of religion and spout absolute shite all over the planet. She said 'son, you know what makes these people dangerous, is the fact because they believe any shit they will also teach any shit and walk you off the end of the planet into a dark defoid'
Momma was right. Wise woman.
Bob, don't let my opinion confuse you like it does tha' Nav. IMO we really don't disagree here. We may make different points and say things differently, but based on what you say here I don't think we disagree, and I'm not trying to put words in your mouth...like you did me with your "...hey ho chaps..." comment. I also agree with you that an A99, can produce some terrible TVI and CM currents issues...but I've had several A99's that don't, and I think there are more that work as intended, than there are that don't. I also believe that most of what happens is due to Solarcon not getting the soldering right on every antenna the produce. Have you never bought a bad or lemon product?
In this thread I was just trying to describe what I see and what was on my mind regarding the A99's need for a feed line or not, while using my VA1 connected directly to the physical feed point where 99.9% probably believe is the real feed point, the SO239. I grant you that the electrical feed point is probably up inside the base mount at the coils.
I was trying to show that the condition of the match does not change without the feed line attached, or that the A99, will not fail without a feed line or a mast attached to the antenna. And thus there is a counterpoise that makes the A99, work, but it is not what we generally think..............
I referenced the work that Steve Yates reports, but when I originally tested my idea it was long before I ever heard of Steve Yates or his report. It was an observation that I made a long time ago and all I knew for sure then was the antenna worked and showed about the same match either way.
I don't think Northern35, believed me either, and I was not really convinced when he reported his results that suggested my testing was wrong. He didn't admit as much, but I knew that his results, right or wrong, might have left in the minds of others that my idea and test was dead wrong, plus he was using a more accurate analyzer so reports say and that might speak for more accuracy too. It was not a toy, like my VA1 that I got out of a Cracker Jacks box. Others no doubt viewed his results as being right on the mark, and many probably still believe that jumbled pattern supports the way this CBBS claim applies to just about every A99, made over the years.
Bob, you have to admit that in your area there is a whole clan of folks that make it their lives preoccupation to literally run the A99, into the dirt and without exception. Or, are you suggesting now that there might be some really creditable ideas and theory that comes out as ture blue in the CB world?
I don't have the skills or education that helps me to really know for sure, if what Yates reports is true or not, but it does seen to make sense to me...based on my understanding of what he reports. And it is also not my claim to be understanding everything he reports either.
You post:
I don't read Yates saying this at all. IMO, he suggested that the EFHW can produce CMC if the match is not resonant and resistive. He further adds that under the ideal conditions where the match is both resonant and resistive that the counterpoise only needs to be .05wl long. At this point Yates does not discuss CMC per se, but in his next example #8, he relates to Moxon's findings, and Yates says at first he agreed with Moxon. He did later recount he could see things different, but I took that claim was just saying the EFHW could be successful in several different configurations that accomplished the same balanced load.
Moxon's idea added an equal amount of length for the .05wl counterpoise to other side of the capacitor, and both men claim this will balance the load and mitigated the CMC's on the coax. Moxon and Yates also indicate this addition on both sides made the antenna a bit more reactive, and later Yates addressed that issue.
There is more, but you'll just have to read on from here. My testing idea was not trying to check anything that Yates or Moxon claimed in their reports.
From the original report that I made some time back, I received some comments that my results were not accurate. It was said flat out, just like the countless old stories we've all heard for years "...the A99 uses the feed line to complete the other half of the 1/2 wave antenna, and it won't work right without the other half, and as a result it produces CMC issues, etc...."
I take the old CB claims to possibly mean, the A99 will not work and the match likely goes to hell in a hand basket without the necessary feed line attached. That's all I was testing for, and that is all I asked anybody to try and confirm...one way or another...just to see if my test was duplicable.
Bob, I think my video proves I can duplicate the results, but you always raised some reasonable issues as to why what I reported could be wrong, and I considered exactly what you suggested. You told me you didn't understand what I asking for when I requested somebody for confirmation.
What do you think now, am I just talking "gibberish" like the Nav tells us?
35, tested the idea with his antenna isolated using his minVA, and that was a little different from what I had done initially, but he reported the match went to hell in a hand basket, and that doesn't confirm my findings after doing my comparions either way, with or without isolation of the mast.
At that point I figured it was possible that he could be right however, and that could be the way the A99, will respond without a feed line attached. I had the feeling that 35 was not really sure, but he offered to do the test over again, and I appreciate that cooperation.
If he get the same results...then what do you think folks will believe, including this old man?
Forgetting the issue you raised about where the feed point really is on the A99, and in light of what you claimed above, about your expectations being the same as mine. If you tested your analyzer the same way...what do you think 35, will report when he does it again?
Do you think 35's first report was good on not?
Do you think my video showed what I have been claiming?
Do you think if I were able to do the same type of test with my VA1 right where you suggest, using the guts for my exposed A99, that I would see some remarkable difference in results, compared to what I showed in the video?
Bob, I really do respect your opinion, but sometimes I have opinions too. I hope we can still agree to disagree on some issues, and still talk. I could care less what the "one line wonders" on this or any other forum might think. I do still respect honest opinions of some however, even when I might disagree.
Thanks for your comments.
Nav, take this sage advice from a wise old man...you have nothing to worry about, your momma taught you well, plus you have your EFHW Spideplane that will take you anywhere you wish to go.:pop::pop::pop::pop::sleep::sleep::sleep:.
you are not talking gibberish eddie i just did not get what it was you were trying to prove,
how many people believe the feedpoint is at the so239 is of no concern to me unless they start telling me hooking to the so239 is the same as yates shows us in his diagram,
there is no clan of people in my area that "make it their lives preoccupation to literally run the A99, into the dirt and without exception", you must be thinking of jazzsinger,
nav & frogger are the only members on here in my area, nav is using an a99 with a smashed up 1 bent radial spiderplane, he can't talk to my old buddy vanny "thecobraman" since his spiderplane blew away just like before he added the spiderplane,
frogger is using an imax that's gone faulty with signals/swr up and down like a fiddlers elbow soon to be swapped for a gainmaster,
the people in my area judge the antenna by how it works vs other antennas and how they stand up to our weather, their popularity suggests they don't think they are junk, they can't talk as far as the people with better/longer antennas either but nobody in my area wants a buttfugly i-10k or vector on their roof apart from my blind buddy al who can't see it,
a99's work just as well as any other no radial 1/2wave i owned and in some cases as good as a sirio 5/8wave with 12 short radials on the same pole ( pick yourself up off the floor jazz ) as i have said before,
people claiming they are a dummyload in a stick just makes me laugh,
a99's having cm current on the braid is not caused by dodgy soldering,
if the solder breaks loose the vswr goes through the roof,
all a99's can suffer the same thing same as any other no radial end-fed,
if you see notable change in vswr when changing coax length a few feet you have cm currents on the braid, squirt some juice up it and you will likely have burned lips and rfi in the shack,
since you can't operate without the coax you have to live with the cm current issue, hope you pick a lucky length mast/feedline or isolate like nav,
why not cut to the chase and ask
"WHO THINKS THE A99 WON'T HAVE A GOOD VSWR WITHOUT COAX"
if you had asked that id be clear what it was you were trying to demonstrate,
i expect 35s to get similar results to you if he sets the test up the same way;).
Here is an email I sent Steve Yates and his response.
Hi Eddie,
Thanks for the note.
I have never used a Solarcon A99 so I can't give an opinion based on experience. I have been very skeptical of all of the hype it has received ever since I first heard about it a couple of decades ago.
Below is a link the describes what is in the antenna and a reversed engineered schematic. I don't really understand reason for the circuit configuration that is used. I don't see anything that would prevent common mode currents on the coax although if operated at a frequency where the antenna is truly a half wave there may not be too much to worry about. At other frequencies where the antenna's impedance would start to drop I'd expect the currents in the shield of the coax to increase.
http://xoomer.virgilio.it/ham-radio-manuals/a99.pdf
From what I can see the antenna is no different than any other end fed half wave vertical such as a J-Pole, Ringo, etc. except for the unusual matching network that may be very lossy as the author indicates. This loss is probably what gives it the wide band response everyone seems to brag about. At 27 MHz it is possible that the coils may have enough reactance (>>Z) on their own to function as a simple broadband, high impedance transformer and therefore not need a resonating capacitor to bring the antenna coil up to many thousands of Ohms reactance (in a transformer the reactance of the windings should be at least 4 times the impedance on a given side of the transformer). However, there are capacitors of sorts in the design so I am not sure.
Sorry I can't be of more help.
Take care,
Steve - AA5TB
To: Steve Yates <Steve@aa5tb.com>
Sent: Saturday, August 10, 2013 9:09 PM
Subject: Questions on the EFHW
Steve, I am Eddie Romans. I am not a Ham, but as a hobby I do try and understand antennas, and the ideas that make them work. I've read your article on EFHW's many times, and use it as a reference link from time to time. I find your ideas revealing to me.
We are discussing the Solarcon's A99, for CB, at the moment.
As noted, I have read you article on EFHW antennas, and would be curious if you have ever consider that matching design, and have a brief opinion that you could share?
My main interest is, does this design almost guarantee to manifest common mode currents unless we add radials and isolate the antenna from the support mast, or do you think the design could produce a balance similar to your idea in your article?
Thanks,
Eddie
edromans@comcast.net
Cheers Eddie, Here's a nice little number I think you'll like. 1968.
The Seekers - A World of our Own (1968 - Stereo, HQ video) - YouTube
Nav, I was moved to thank you, but I decided to add some of my comments in addition to thanking you.
I recall this quaint little tune from the past, but the words were and still are totally unrealistic pie in the sky...considering what both of our Democratic styled governments are gradually turning us into...a focus on the collective and not the individual.
We both use to be proud Nation's with a compassionate idea of a melting pot for progress, a blending from all nations on Earth in our midsts seemed desirable. But sadly to say...we didn't remember the story in the Holy Bible about the tower of Babel. Our reprobate minds prevent us from understanding the lessons from God, provided in that example about the collective that was under Godless leadership in positions of power.
Unlike the words of hope in this song, we still can't survive even if man is forced into distinct groups by God's will, and again we are spread all over the Earth renewed in to collective groups. Man can do just about anything he desires, but this World has a destiny, and no song or will from man is going to change that.
So, again the words are just idealistic babbling BS from some yuppie minded nut...back in the '60. These ideas won't work, even if both of our Nations took the road toward Isolationism again.
Don't you know the elites in power in this world are slowly nudging the people into destruction, and no song we will ever sing will stop that.
I like the melody though.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
