38LSB is dead as a doornail
Do you miss The Blue Waffle?
  • Yes
    Votes: 3 11.1%
  • No
    Votes: 18 66.7%
  • The IHOP Special of the Day! No Thank You :-)
    Votes: 7 25.9%
  • Total voters
    27
(y)How does the water make it louder? The truck in my avatar is a 91 C350 Centurion conversion. A 4 door one ton bronco with BFG 35" tires and no lift. It has a 460 with glass pack duals that exit in front of the back wheels. I love the sound of it with the windows down, like its in stereo.
Reactions: 357magnum and Rwb
Loud glass paks or cherry bombs God I miss the old days!!!
Wait...!!!! Good Ole' Days? I still drive a loud truck, just have a 5" dia. exhaust. Aftermarket MBRP on Dodge 3500. When I installed it there was a muffler, I think, but it was straight through. Could drop a coffee can right through it.
The water breaks or cracks the fiberglass in the muffler...
Rwb , Had the same exact setup on my older 318 Ram , so rappy it was almost annoying after a while !:LOL: Ralph , now what's up w/ that ? As we get older you are supposed to make the truck lower for ease of getting in/out . What did you do ? Ad a lift kit ! Makes total sense to me !:whistle::LOL:
Reactions: Rwb and S&W357
Ok that makes sense. Over time the fiberglass seems to blow out anyway, I guess this just speeds up the process. We went on a road trip one time and I could tell it was louder at the end of the trip too. I will see if I can find a picture of my setup.
Reactions: Rwb
The cool water hitting the inside of the glass packs causes them to burn out very quickly making them much louder. Worked on Thrush Mufflers & others as well.
SIX-SHOOTER
i like how they sound on my ole buggy.and the extra mile to the gallon helped too.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
