Hello,
No guru either....but very enthousiastic
Take a look at your antenna like this:
Example:
Your radiator has a "resonant" frequency of 27.0 Mhz
now, the directors are shorter...so the individual resonant frequency will be sligthly higher. If we would take the directors away from the quad and measure them seperatly you could come up with (for example)
27.2 ..27.4..27.6 MHz.
Now, those resonant frequencies equals length of the loop.
If your really into "beams" you tend to start thinking in "resonant frequency" rather then lengths.
There are a quite a couple things that influence that resonant frequency.
Two of them are : diameter and secondly if its bare ware or insulted.
It is very plausible the resonant frequency will shift several 100 Khz's by changing diameter etc.
Say you or someone else has done there homework and designed a beautifull 10+ dBI 4el cubical quad.
The length of the element is based on the resonant frequency.
If this is designed with #10 bare and your going to use # 16 it is logical the resonant frequency will shift, providing slightly off optimum respons.
Wheter or not the effect is there, can be confirmed in moddeling software.
And if it can be "spotted" using software...it still is the question wheter or not anyone can hear the difference in "real life".
We all do our best to "gain" 0,1 dB extra...but in reallity no one can notice of course.
However, you have asked the question, so wheter or not anyone can "hear" the difference the question probarbly lies a bit more in the direction of: Would you be happy with the thougth that it migth not perform to its potential ? I guess not, so:
Wise would be to get confirmation if it is still "within the limites".
My best guess would be you have a "plan" for a 50 ohms direct fed 4el quad.
If that is the case, it would be more reason to get confirmation as diameter will effect ALL parameters, including impedance.
But heck, im often too precise...and its not nuclaire sciences were talking about hihi
Hope it helped !
Kind regards,
H.
